1999 Boxster
I am trying to diagnose to OBD codes (P1128, P1130) and was checking for air leaks. I took off the hose runing from the oil separator to the intake manifold and noticed there was a small amount of oil in the tube (evident at both ends). Is this normal or is it a sign that the oil separator needs to be replaced? :help:
Normal. As long as you do not see oil in the throttle body it is okay.
If you did not see my post when I was having the problem do a search on P1128.
