Hi- I keep seeing loose throttle bolts as a cause of CELs -Are these the four bolts that attach the throttle body to the "intermediate piece" (the tee that splits to the two manifolds)?
Those are the throttle body bolts. 1128 is usually a vacuum leak (likely the oil seperator bellows)
