Does anyone know if turbo twist wheels (rears 10" 45mm offset, fronts 9" 50mm offset) will fit an '02 narrow body cab?
TIA
Cheers,
Stan
The fronts should be fine - as long as you go with a 235 or smaller tire. 245's will rub and some brands of 235 may rub slightly on a 9" front wheel.
On the rear you will need large spacers or different wheels. The offset for the rear with a 10" and 285 tires should be 63 mm - so you are about 18 mm off. Other folks might have some input too...
