I apologize if this is somewhere in the archives but I did a search and couldn't find any specific information on how to remove the screen/filter from the brake fluid reservoir. I need to flush my brake fluid before a PCA DE this weekend and I'd like to remove the screen on the top of the reservoir so I can remove as much of the old fluid as possible with my Mitivac pump. I read some other posts that you just take some needle nose pliers to remove, but mine doesn't seem to want to come out. Does it only come out a certain way, meaning it needs to be rotated in a certain orientation?. '99 Boxster, if that matters.
  • Like 1
I don't remove them because sometimes they break.
I drain fluid from the RR nipple until the level is at the sensor in the reservoir. Then fill the reservoir and start bleeding. You start at the RR.
I use the Motive pressure bleeder so when I drain the fluid the Motive tank is empty. If your Mitivac is the one I have then it creates a vacum at the nipple.
  • Like 1
Thanks, that was going to be my secondary option. I just figured it would be a little faster to suck all of the old fluid out of the reservoir with my Mityvac pump as other's have suggested before putting the new fluid in. I don't know how other's got the screen out but I tugged on it pretty hard and it wouldn't budge. I had visions of brake fluid getting flung all over the place if it broke lose with those pliers. I'll use your procedure instead. I just picked up a Motiv pressure bleeder so it should go pretty quick.
  • Like 1
I threaded aquarium hose used for bleeding brakes through slots in the screen and sucked out the brake fluid leaving the screen in place.
Edited by adsach
At the TSBL meet we pulled the screens out with long nose plyers. We used a towel to cover the surrounding area. The screen popped out without any problem and did not spray blake fluid around. :D
Rich
