Hey guys,
i have seen this poseted before but no one seems to answer anyone...
does anyone know how to remove the front console ashtray ??
Please let all of us know if you do know.
thanks Marco
I have posted this here serveral times....
Remove the trim around the cdr/pcm and the ac control head. Remove the ac control head and you will see two t20 screws for the ashtray.
  • 3 months later...
OR...if you just want to remove the ashtray insert to empty or clean it...there is a small spring-action slider release , same color as the ashtray plastic just inside the front lip located between the lighter socket and the insert. Slide it towards the lighter socket and the tray releases...took me a while to figure this one out :cursing: !!!
