well it seems the main relay is acting up, the car completely shut down at a light. The tow truck driver came and jumped the relay but its still acting funny.
The battery is less than 18 months old, Im pretty sure its the relays, the car had some flood damage at one point. The AC relay has also acted up peroidically.
There are two banks of relays. One for the engine DME, AC compressor, start lock, secondary air pump, and the spoiler extend and retract in the rear trunk (behind the carpet). The other (for most of the relays) is up under the dash on the left side - above the fuse panel.
For a MY97 Boxster
Position - Relay Function
1 - MFI (DME)
2 - Ignition/Oxygen Sensor
3 - Spoiler Extend
4 - Air compressor
7 - Start Lock
9 - Spoiler Retract
10 - Secondary Air Pump
