If you actually have a bad head gasket (which I cannot see in the photos), you would be the very first head gasket I have ever seen fail on one of these engines.
By far, the two biggest reasons for intermix on an M96/97 are cracked cylinder heads, or cracked cylinder liners:
13256d1288005547-2001-boxster-s-cracked-  644655d1341076751-2007-997-3-8-cylinder-
Best engine? I dont know. A lot of people has a problem with boxer engine in low milage. My engine blow up last week. IMS was replaced. Somethig different damage engine. Opsss
Odesláno z mého BBB100-2 pomocí Tapatalk
  • 2 months later...
  • 11 months later...
My engine also blew up.  The more I learn about these engines, the more I realize how much of a crap shoot it is.  Some folks are lucky and some folks are not so lucky.  Going to do a LS swap.  Will probably outlast every single m96 engine on the planet.  I do not see these cars around in 30 years..
Welcome to RennTech:welcomeani:
Before going down the LS path, you might want to talk to one or two of the forum members that have done the LS swap; general consensus is that they would never do it again.
  • Like 1
Hi
Some people are doing swaps from the VAG group, straight bolt ups. The Audi 1.8T into Boxsters seems to work well.
Berni
