Are they H7's? and should I get 6000k or 8000k? :(
Shawn
Heres their chart...
Model (Low Beam) Price Model (Low Beam) Price
H1 $280 9004 $280
H3 $280 9005 $280
H4/9003/9415 $280 9006 $280
H7 $280 9007 $280
H8 $300 D2S $300
H9 $300 D2R $300
H11 $300 880/881 $300
H12 $300 884 $300
H13/9008 $300 889 $300
Aftermarket HID light kit problems
I finished wiring up one of the headlights, and I ran into a problem.
I am getting a computer fault code saying "Check dipped beam" It appears to be cutting power to that headlamp.
Any suggestions???
It is a fairly simple wiring, but I used the existing two headlight low beam wires, and left the small backup light wires cut for fear the ballast would blow the non xenon bulb. I fear that this may be the problem.
Help?
Actually maybe the wires are reversed? I assumed from the ballast black would go to black, and white would got to brown?
Hope this makes sense....... :(
