I did a quick search and couldn't find anything on this subject, but my turn signals and hazards have stopped working. Everything else in the car is good, lights, other electrics etc.
Anyone recommend where I should start looking for the problem.
The fuses are fine. What would you suggest next ?
Thanks a lot
I'm a bit of a novice, so forgive my ignorance, but is the flasher relay in the same place as the fuses ?
Thanks again
Thanks a lot
No erratic behavior. They simply stopped.
As you all know, the porsche is not the easiest machine for DIY. I have dabbled with a few things, the MAF etc, but have never got up to look at the relays and stuff. Are they tricky to get to, or do I need any special tools
