2001 base Boxster.
I imagine there are up to 8: 2 pairs for the chassis brackets, 2 pairs for the links.
Thanks.
Swaybar to side member (M10 1.5)- 48ftlbs
Swaybar to droplink (M10) - 34ftlbs
Droplink to hub carrier (M12) - 63ftlbs
My guess would be the droplink bolt where it attaches to the swaybar is your culprit. This is pretty common and fortunately an easy DIY. I'd recommend loosening off the bolt, then torquing to specs above to make sure it is properly torqued.
Good Luck,
Graeme
Good Luck,
Graeme
How does one access the swaybar bolts? I just lifted my Boxster and did not readily see them.
Are they behind the plastic shielding? I did not remove the wheels.
Good Luck,
Graeme
Thank you, Graeme.
Good Luck,
Graeme
Thank you, Lemmy.
How're things in Alphaville?
