Is the part in this diagram?
If so, which item?
Its the crossmember that goes from 1 chassis rail to the other and acts as the lower radiator support and the front bumper lower apron rests on it?
Its not actually in that photo though. Does that give you any ideas?
Is it item 3 in this image?
No its thin and its like a reinforcement that sits back about 12 cm from front crossmember its self and has a series of holes for the front apron to attach too.
I have the Gemballa body kit on it now so I need to attach it at that point because its fibreglass.
The piece would be 20mm thick and 60mm wide and it mounts off the bottom of the chassis rails??
