Help. My driver side window all of a sudden, when opening from outside, goes all the way up before I close, preventing it from closing properly.
If I use the outside handle, then it goes all the way up. The inside handle seems to be working OK (means: does not cause the window to go up and down). The only way to close it now is to bang it against the upper plastic molding for it to go down a little bit and then close it.
Questions:
1. How to fix it?
2. Do I need to open the inside door lining to get to some kind of sensor in the door handle? If I do, how to open the door panel cover correctly without destroying it?
Thanks for any info.
