I have read the previous posts so I appologize for my ignorance. What are the instructs for removing the front bumper on an '04 996TT cab. I'm installing the Techart GTS next month.
Loren to the rescue!
Check out the "DIY" section under "996, Adding the third radiator"....it shows you how to remove the bumper, its an easy job...done it myself recently.
I have checked that out and just wanted to make sure it was the same for the TT. Thanks Ben!
Statman..Its the same on the TT, while your there clean all the rads, my TT rads were completely choked up with leaves at the back...
Undo the two rads that are screwed together and clean behind to...I put some pics up on 6speed about it....search BigBadBen
Cheers.
