I purchased a '99 C4 earlier this year with the PCM1 system. I did not get any discs with the car and called Navtech to inquire. The rep I talked with said the 2001.1 discs will work. From browsing the forum I'm under the impression the disc reader was upgraded from 8 bit to 16 bit in '01. Is this correct? If so, will the 2001.1 discs work only with a 16 bit reader or both 8 & 16 bit? Also, does anyone know the price for a 16 bit reader from Porsche and if it is a significant improvement over the 8 bit unit? I understand it easy easy to swap out. Thanks!
