My '01 996 C2 which I got new in '02 is now due its 15k service. The dealer is reccomending that the brakes be flushed since it is needed at 2 years, even if the car has only been used for 1 year and 15k. Yeah or nay?
I agree that brake fluid should be changed at least every two years and more often if you track the car. This will remove moisture and air from the system that are byproducts of the tremendous heating and cooling that the brakes do during normal operation.
This is a easy DIY with a power bleeder (about $40) and about 1 hour of time. I have a DIY instructions for brake and clutch flushing/bleeding in my DIY section here
