Here is my how to on Installing them..
First remove the old sill. just stick a screwdrive under the metal and it pops up. Then remove the 2 hex screws that are holding the plastic sill down.
You can't remove this hole piece, just pop it out from the front area. You just need to drill a hole in this corner.. so lift it while your drilling.. the wire runs through this drilled hole
Get some double sided tape and put this little box in the second to last box..
Run the supplied wire up into the fuse box area.. then over to the footwell light
Now I got power from the entry lights underneath the steering wheel..
The book has you tapping into other sources in the door harness, but this was much easier..
I spliced into the footwell light under the wheel here
Hide all the wires and your finished!!
That is about it.. for the passanger side.. do the same thing and tap into the footwell lighting..afx.sized.jpg
  • 3 months later...
I also just bought these sills. Would it be possible to get the TSB for them? I'll definitely post my experiences when I am finished.
Chris
Chris
Chris,
You've got mail...
Chris,
You better connect the door sills to the front footwell lighting.
Much easier than what is described in the TSB.
  • 2 years later...
Ok I had mine installed but found they flicker. I have given my car to my trusted car audio and electronics guys who now say the wiring matches up with the info on this thread. So I'm at a loss at to what's going on, unless it's because my car is '08 spec, which sounds unlikely to me.
My guys say a correct wiring diagram would be useful.
Any advice?
Any advice?
I do not know if it is the case on your car but on the Gen 1 Cayenne's - if your car did not have door access lighting as standard - then the door lighting option had to be turned on with a PIWIS tester/programmer.
The coding needs to be set to menu item "Door warning light/entry light On".
Any advice?
Thanks Loren. Got back today and found they'd fixed the issue by re-wiring them to the door lighting instead of the internal lights. Seems the original install which ran off the interior lights caused both flickering and delayed shut off, since they'd stay on for a few secs in concert with the interior lite.
Oh well, all good. It will just the list time I get my friends Audi/VW dealership workshop to try installing an electrical based accessory like that! So much for a quick install done in a couple of hours while I was at lunch!
You should have them connected to the front door control modules like the TSB shows, otherwise they flicker on a 2008.
Yeah, handy if you have the TSB... I am not a contributing member so I didn't have access to it. No matter it was worked out correctly in the end.
I would love the email for the install on these as well if possible, thank you!
Just have an experience auto electrician follow the photos of the install. I had mine sorted easily after the original mistake that way.
  • 10 months later...
Chris
Chris,
You've got mail...
Loren,
Would you be kind enough to forward that TSB to me as well?
Many thanks!
KR
EDIT: D'oh! I found where the TSB's live! No need to forward it. Thanks!!!
Edited by rizzo
