I have the opportunity to get a pair of used C4S Sport Exhaust mufflers for my 2000 C4. Would these fit? I would need all the electronics to make it happen, but first question is if it is feasible...
Yes, all the Carrera mufflers will interchange (in pairs). The tailpipe tips will not interchange because of the rear bumper redesign for MY02 (not will the C4S tips fit for the same reason). As long as you re-use the tips from your car you should be fine.
Thanks Loren. So If I pick these up, I should be be able to get them to fit my '00 if I reuse the existing tips? Can I just order the vacuum tube as well as the electronics to activate this?
Thanks so much for your knowledge and insight!
Yes, just the tips change should work for the mufflers.
I don't think Porsche sells the electronics/vacuum kit by itself. I gave mine to a board member. Without the electronics/vacuum kit the PSE will be always open (loud). That is the way mine is. I don't find it too loud - I just don't drive through my neighborhood at 4000 RPM.
