I have an '05 turbo S that is hard to start when it's hot. When cold, it's perfect, starts easily and idles well but when I attempt a hot start, it's reluctant and, kind of, idles on one bank and then catches on. Anyone can shed any light ? thanks in advance.
Not sure if it is just a turbo car issue.
My '02 911 has done the same but not consistently. Took it to the dealer "couldn't reproduce issue" & no error codes or anything.
:unsure:
My '03, which I had for two years prior to getting the turbo S, had always started normally. This one is a bit reluctant to start when hot, and the dealer couldn't find an error code even though he noticed the "problem".
Back in late 2001 Porsche had some problems with TT's not starting due to fouled/wet spark plugs. At that time they raised the heat range on the spark plugs from 5 to 6. The higher hear range plugs should be in your car (Beru 14 FR 6 LDU).
