I bought this kenwood sub which is only 3 3/4 " in height. I am going to put it behind the passenger set. I need tho run the wires so they get behind the CD player. How do I get back there. I am new to all this. there are a plastic panel on both side of the stick shift. Can I get those off and route the wires to the back of the stereo and then put them back?
thanks
run the wires throught the center console. the trim around the a/c controls and radio can be popped off by hand. there are screws that will allow you to remove the entire chassis that holds the a/c controls and radio. this will give you the access and the route that you need.
