So I finally fixed this problem and it did turn out to be the MAF. This is a 1998 Boxster with 61K miles. The OBDII readout of the Long Term Fuel Trims were 29.7% For those who have this problem in the future this is what I tried:
Changed the plugs
Changed the fuel filter
Used a bottle of techron
Searched for intake leaks
Checked the oil separator bellows
Checked the oil filler tube
After all this I did notice a slight improvement in the fuel trim numbers. They decreased to about 27% but I would still eventually get a CEL.
One other symptom was that the car would stall once when cold.
I then conned Trygve into letting me use his car as a guinea pig. I took MAF readings from his car at various RPM and got:
idle 3.6 g/s
2000 rpm 7.8 g/s
2500 rpm 11.4 g/s
3000 rpm 14.8 g/s
3500 rpm 16.2 g/s
4000 rpm 17.8 g/s
4500 rpm 22.3 g/s
On my car the numbers were:
idle 3.5 g/s
2000 rpm 7.2 g/s
2500 rpm 10.0 g/s
3000 rpm 11.7 g/s
3500 rpm 12.8 g/s
4000 rpm 15.0 g/s
4500 rpm 17.9 g/s
So my numbers were some 20-30% low. We then swapped MAFs and the problem followed the MAF. So I bought a new MAF, installed it and now my car reads:
idle 4.4 g/s
2000 rpm 8.0 g/s
2500 rpm 10.3 g/s
3000 rpm 14.0 g/s
3500 rpm 16.2 g/s
4000 rpm 19.4 g/s
4500 rpm 23.2 g/s
It was about 75 degrees during the first two readings and 65 degrees for the last set.
As posted previously the best source for the MAF appears to be:
http://www.autohausaz.com/catalog/lookup_p...FToken=80622876
The part I got even had the Porsche Part number (996 606 123 00) on it.
You can get a set of security or tamperproof bits (you need a Torx T20 security bit) here:
http://www.harborfreight.com
Item number 91310 for $7.
I would suggest that if you have an OBDII reader that you take baseline readings of your car so that if you have a problem in the future you know what your readings are for when the car was running properly.
Excellent procedure and invaluable data. Thank you - Gary
Changed the plugs
idle 3.6 g/s
2000 rpm 7.8 g/s
2500 rpm 11.4 g/s
3000 rpm 14.8 g/s
3500 rpm 16.2 g/s
4000 rpm 17.8 g/s
4500 rpm 22.3 g/s
idle 3.5 g/s
2000 rpm 7.2 g/s
2500 rpm 10.0 g/s
3000 rpm 11.7 g/s
3500 rpm 12.8 g/s
4000 rpm 15.0 g/s
4500 rpm 17.9 g/s
idle 4.4 g/s
2000 rpm 8.0 g/s
2500 rpm 10.3 g/s
3000 rpm 14.0 g/s
3500 rpm 16.2 g/s
4000 rpm 19.4 g/s
4500 rpm 23.2 g/s
