Overheated central control box
Olaf
Recently I noted that the central controlbox in my 964 is overheating.
It's quit normal that it gets a little warm - but this one is :cursing: HOT -
If it wasn't mounted upsidedown underneat the dashboard you could fry an egg on it ....
Used the Bosch 'Hammer' to eliminate 'failing' objects .... finding myself changing out the lambda-sonde ...
It hasn't changed :(
When I'm having the windows closed and the roof shut, the airco off - then it'll take a bit longer to heat up (but it still does).
When I'm either running the AC or having the top down .... it starts 'cooking' within half an hour or so (this is when driving offcourse).
Anyone familiar with this problem ?
Thanks in advance :thumbup:
Olaf
I can't think of the control unit you are talking about. does it have any numbers on it?
It does ... but unfortunately the Porsche is parked at the otherside of the channel :( .... I'm currently in the UK <_<
For a lefthand drive you can find it, sitting in the drivers-seat and dropping your left-hand from the steering-wheel. Now move your hand under the dashboard and move up ... there you'll find an aluminium box - a bit bigger than a packet of cigarettes :lightbulb:
Its mounted on a small frame - which is mounted with two 10mm plastic nuts :wrench: to the body of the car - there are two connectors on the box.
  • 7 months later...
