Hi everyone,
I've been trying to track down a potential cause of these two error codes and I noticed that I've got a leak around the base of what looks to be my oil pressure sensor. It's located near the front of the right cylinder bank and it has two wires coming off the back. Could a leak around this sensor be a potential cause for these fault codes and since the sensor appears to be working, is there sime kind of replaceable gasket for it?
Also, I think I've got a similar problem occurring at the base of my fuel pressure sensor. Could this also be a cause, and am I going to have to replace both sensors?
Thanx in advance,
I'm getting 1123 and 1125. I was in the process of trying to locate the oil separator bellows hose to see if it has any leaks, when I discovered this problem. Would you happen to know where it is? I can't seem to find it.
My CEL was for the P1123 code and was diagnosed with the following parts needing replacement:
996-606-160-01 Idle-Speed Sensor
996-606-123-00 Mass Air Flow Sensor
000-043-205-01 (2) Vacuum Hose.
