According to the workship manual, the factory shims are 1mm thick. To get more front camber you need the thicker shims. What are the part numbers?
Shims for the track control arm MY04 GT3.
996 341 543 90 Shim 1 mm
996 341 543 91 Shim 2 mm
996 341 543 92 Shim 3 mm
996 341 543 93 Shim 7 mm
They all appear to be special order.
You might also try Porsche Motorsports NA if your dealer can't get them. They stock them for the Cup cars. They are pretty pricey if I remember right.
Karl
Edited by KarlS
