Driving back from work I think I ran out of gas. The oil light came on followed by the engine dying approximately 15 seconds later. The fule gage was reading at the first empty bar. Coasted to a surface street with a slight crown an parked by the curb. Got gas with my other car and put 8 gallons in the tank. Tried to restart and no joy after about 30 minutes of intermittent cranking. Can the fuel lines get to a point where fuel doesn't go in no matter what?
Thanks for any thoughts,
CW
Assuming the engine stopped running because you ran out of fuel, it should have restarted after your numerous attempts. I wonder if your immobilizer is preventing the car from starting? If you turn the key off and then turn it on, you should hear the fuel pump run for a few seconds. If you cycle the fuel pump a few times, that should prime the fuel rail, and the car should start, if the only problem was you ran out of fuel. Lets us know what happens.
Thanks for the reply, and a newbie question: What is the immobilizer?
Also, this moring I tried to start the car and got a large backfire. Afterwords it still would not start or even hint of starting.
Bruinbro
