If you have tried to repair the mirror door hinge mount on the sun visor only to have the little mount crack again you may wish to consider a relatively inexpensive fix.
The mirror insert itself is replaceable. You can choose the lighted ones (996-731-903-01-01C) for $48.00 each at Sunset or you can choose the unlighted mirror insert for $11.66 each also from Sunset (986-731-901-01-01C).
Simply remove the existing plastic insert and pop the new ones in. I choose this time to go with the unlighted ones. They are cheaper and if they break again, I'd rather pay $23.00 than $96.00.
If you go with the lighted ones you will have to splice into the existing wiring in the mirror assembly or solder the wires to the contact points in the mirror assembly.
The unlighted ones took 10 minutes to install and the lighted ones may take 30 minutes depending on how quickly you can solder.
Hope this is useful...
Jim :drive:
Jim, Did the replacement mirrors last any longer than the originals, just wondering if they actually improved the design or are they still them same :censored: quality.
Glenn
