1988 Interior door panels are not tightly fastened to the door. I recall a mechanic who disassembled the doors on a 928 and added some clips. Could I do that to a 944? How much work is involved? Thank you!
Seems that the screws have vibrated loose. One of the 2 bolts under the arm rest is missing. Do you have the specs on the bolt for a replacement? Perhaps a dab of Lock Tite is in order. Thank you!
The copy of the parts list I have shows 3 self tapping screws (per side) for the armrest. If that is what you mean they are 4.8 x 16. 900 143 046 02 self tapping screw and retail for $0.29 each.
  • 2 months later...
