How can I remove the plastic "junk tray" trim under my standard radio CDR-23? I would like to get access into that area to hide phone/PDA chargers. Do I just pry it off or is there a hidden screw/tab that needs to be released.
  • 3 months later...
You must remove the radio (pry off trim around radio / centre console), and back off on the screws on the temp control unit, then remove the radio screws. The dummy storage unit slided up under the radio...comes out easy....but then you will have a hole....
