It does not mean that your airbag is non-functional. It means that there was/is a problem somewhere in the airbag system. The problem usualy results from a grounding failure on the seat belt. You will need to have the light reset by the dealer, although it may be possible to fix the problem itself (and leave the light on) without the dealer.
