Hi All,
New to this forum, so if this has been posted before sorry!
I am going to replace these sensors myself and wanted to find out where exactly where they are before I get into the process. Any DIY tips or tricks are much appreciated.
1997 986 with 47K miles.
Here are the codes for your info:
P0140 Oxygen Sensor After Catalytic Converter (cylinders 1 - 3) - Interruption of Signal
P1117 Oxygen Sensor Heating 1 After Catalytic Converter - Below Lower Limit
P1275 Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Below Lower Limit
P0139 Aging of Oxygen Sensor After Catalytic Converter (Cylinders 1 - 3)
Thanks for any help with this!
P140 possible causes:
Open circuit in signal wire or ground wire of one oxygen sensor.
Oxygen sensor heating not functioning.
DME control module output stage faulty.
Potential fixes:
- Wiring harness
- Oxygen sensor
- DME control module
P139 possible causes:
Oxygen sensor value does not change towards rich or lean.
Potential fixes:
- Oxygen sensor
P1117 possible causes:
Heating current too low.
Potential fixes:
- Contact resistance.
- Heating resistance too high.
- Open circuit in heating current circuits.
- Open circuit in H02S signal wire.
- Short to B+ (output stage cut off).
P1275 possible causes:
Emission values are exceeded by 1.5 x.
Potenial fixes:
- Oxygen sensor
Looks like a bad O2 sensor to me...
Thanks for the very informatiave post Loren! I appreciate it!
I am looking for which side of the engine the fouled sensors are on, I think it is the drivers side. Correct? Is there a diagram of the engine to show where the 1-3 cylinders are?
Thanks again!
