Slight problem with my ignition. I turn the key to start the engine. for some reson the key does not click back all they to the normal (after start) position. so the engine is running but the lights on the dash stay on and the a/c wont turn on.
When I manually turn it just a bit (5mm)conter clockwise, the lights turn off and the a/c turns on (how its supposed to be). You guys think a little wd-40 will do the job?
Any thoughts? :help:
Thx
