Can a later model (2002+) Porsche Sport Exhaust fit a 2000 986S? If not a direct fit, can it be done with appropriate fittings/couplings, etc.
The reason I ask is that I heard that later model PSE sounded better than the earlier versions.
Forgot to mention, I did read archive posts regarding "sport exhaust". On some posts it sounds like only fittings are required on to fit while other posts indicate revised bumper possibly needed.
The design of the sport exhaust changed for model years 2003 and 2004 due to the rear bumper extensions used on those years. The 2003/4 sport exhaust will fit your 2000.
There is however a problem if someone wanted to do the reverse, and use the pre 2003 exhaust on a 2003/4.
