Carrera (not GT3 or TT)
Brake disc thickness, new
front 28 mm
rear 24 mm
Minimum brake disc thickness after machining (1)
front 26.6 mm (1)
rear 22.6 mm (1)
(1) The brake disc must only be reworked symmetrically, i.e. from both sides evenly.
Brake disc wear limit
front 26.0 mm
rear 22.0 mm
  • 5 years later...
front 28 mm
rear 24 mm
front 26.6 mm (1)
rear 22.6 mm (1)
front 26.0 mm
rear 22.0 mm
Do these measurements include 997.1 "S" ?
Thanks in advance.
front 28 mm
rear 24 mm
front 26.6 mm (1)
rear 22.6 mm (1)
front 26.0 mm
rear 22.0 mm
Thanks in advance.
front 28 mm
rear 24 mm
front 26.6 mm (1)
rear 22.6 mm (1)
front 26.0 mm
rear 22.0 mm
Thanks in advance.
http://www.renntech....dpost__p__66842
Thanks Loren!! BTW, Do you have a recommendation for Replacement Pads? I have had the car out for a few NASA HPDE events. I will try to continue with that once or twice a year. Otherwise it is on the road ~10k a year. Should I go to the trouble of a set for track and a set for street or is there a suitable middle ground. I have had no issues at the track with the stock Porsche pads.
Edited by bspurloc
Unless you are running more than 30 minutes at a time I think the OEM pads will be fine. If you are going all out or have runs over 30minutes you can go Pagid - if you go with race pads you will likely want to change back to street pads after events. The squeaking might drive you (and your neighbors crazy otherwise).
Thanks for the info. In NASA they limit time to 15-20 mins per run. I have seen one 30min but not in my classification. I will stick with OEM for now. Mostly street use and I dont want to deal with the squeaking.
