Going to install H&R lowering springs on my 05 Cayenne,has any body run into alignment issues? and do I need the "alignment kit" or is there enough adjustment from the factory.
Not exactly on topic - but I run a custom spring company and if you know what you wanted I would be happy to make them for you.
Kylroy
  • 2 years later...
Installed H&R lowering springs .....very trick nice ride,alignment was easy and fast!
any thing else you can say about them? instal your self? what exactly changed in the ride quality? im about to install eibachs on mie just because i heard the ride smoother than the h&r springs, im ;looking for the best ride, not handleing. is the ride alot worse? shorter travel? faster return, harsher pot holes ect, thanks im dieng to know.
Justin
A little bump to see what other member's more recent experiences are with H&R or Eibach? Any photos of the lowered trucks? Thank you!
x2 the photos w/ springs on or before and after pics
