CEL came on today. I was expecting it because the engine cuts out upon cold starts. I am guessing that it is the MAF sensor after talking to a few mechanics.
Has anyone had this same problem? If so, was it covered under your warranty?
If not, what should I expect to pay?
Jarrod
If it is a C2 then it could be the idle speed valve is carbon'ed up and stuck. I would clean both before replacing any parts. Also, get the fault code.
