I am going to install 6mm spacers in my Boxster MY99 (manual transmission) with SportClassic II wheels
Front: 7,5 J x 18 ET 50
Rear: 9 J x 18 ET 52
Two questions:
1. Recommended by Porsche is 5mm...... Can I try 6mm? no problem?
2. Will I need longer bolts or just standard bolts?
:help: :help: :help:
Regards.
Edited by valcax
If your spacers are 5 mm then your bolts will need to be 5 mm longer.
If your spacers are 6 mm then your bolts will need to be 6 mm longer, etc. etc.
When you say "recommended by Porsche" can you expand on this? 5 mm for all four wheels? And is this a cosmetic change they are recommending or a performance change?
