Hey guys,
On my 99-00 Cabriolet 996 I need to know how to change the B-Pillar moulding as the sun has deteriorated mine.
I have the parts yet I have no idea how to remove the old ones on the rear quarter glass to install the others.
Removing side window seal
Remove the side window seal with the convertible top open and the side window extended. To do this press the microswitch in the windscreen frame and actuate the rocker switch at the same time until the side window is completely extended. Pull the side window seal down and out of the window profile.
Installing side window seal
Remove adhesive residues from above and below the window profile if present. Pull the side window seal from below into the window profile. Pull it in using soapy water as a lubricant. Clean the upper seal end (free from grease and lubricant). Coat the upper surface of the seal (1) with Loctite 480 instant adhesive and bond with the side window profile.
FLAT 6...
How did it go ?
I am thinking about doing it also but I am a little scared about " Pull the side window seal down and out of the window profile" :-(( affraid i am damageing the window.
As i am reading it, the window is stilll installed in the car when you take the seal of ... not ? ?
Same here, can't figure out how to cleanly remove the old seal.
FLAT 6...
How did it go ?
Bump.
I'm really afraid of having rubber left in the metal profile after riping out the old seal.
It doesn't look too easy to clean out the profile.
Also, the seal continues down into the side of the car, if it is glued into the profile all the way then I have to tear down the whole side.
Has anybody done this?
FLAT 6...
How did it go ?
