Loren, I'm doing my tequipment roll bar this week, I have a '03 C4S. PWR seats/memory/heated. Do I have to disconnect the battery, or just turn the key off when I take the seats out?
Secondly, if I do disconnect the battery, do I have to go to the dealer to reset they radio, they told me my year radio doesn't really have a code?
TIA
Chris
Edited by C4S Surgeon
You do not have to disconnect the battery just make sure the key is not in the ignition. However whenever I mess with any electricals I always disconnect the negative lead just to play it safe.
If your radio needs a code you should have been given the code when you bought the car. I know 2004's do not need a code, not sure about 2003.
Keep the key out of the ignition. Even with the car off the airbags are active when the key is in. To be safe I would disconnect the battery.
If your radio is a CDR-23 then the code is stored in the cars computer.No codes or trip to the dealer is needed - unless you change radios.
  • 2 months later...
Trying to do a steering hweel swap but everytime I try and disconnect the neg lead from the battery the alarm goes off? (key not in ign)
dont have an owners hand book I'm afraid, is there something I'm meant to be doing?
New steering wheels in :D feels much better being smaller and a nice thicker grip than stock.
horn and air bag wire connections were spot on with the raid hub
