May seem like a dumb question but what should the volt meter in the dash show when you are starting the engine. I have no idea how old the battery is but it seems to be labouring at times to start. The voltmeter goes down to 10 volts and then seems to hesitate and then after the car turns over a couple of times it fires up.
The voltage indication during cranking is likely meaningless. Should be close to 14 volts after driving/charging.
