Folks, my car started to make a whisling noise. Here is when it happens:
1/ Over 30 miles / hour
2/ Independent from engine speed and /or clutch engaged or not
3/ louder when speed increases
4/ no change with or without a/c engaged
5/ No change when braking or not
6/ no change when turning
The sound is a medium pitched constant sound, almost as if a brake pad is touching the rotor but it does not change if I push the brakes. It does get louder when speed increases and is audible from within. Noiae doeas not seem to be louder outside the car ie driving with windows down does not increase the loudness of the sound.
Idea's??
HarryR
Idea's??
HarryR
I can only speak from experience, but mine is the hood. Sounds like a high pitched squeal. It comes and goes, depending on something? I dont know, but my hood is up above the lip of the front bumper by about a .125 (maybe a little more). I was told to adjust the rubber bumpers inside the hood where it closes down. Try that and see if that helps. I put small towels in the groves in the front trunk to test and see if that was it, and it killed the whine... Basically my bumper is to low from when it was installed and my hood does not go below the lip.
Edited by c4bliss
I will try that one but I had the locking mechanism for the front deck lid replaced last year and my hood is flush. I will check that out. The sound is indeed a squealing sound but it sounds more as if it is coming from a friction like a brake pad having continuous contact with the rotor, it sounds definitely as if it is coming from the back. As I said, the car has to move, the volume increases somewhat from 30 miles onwards ( that's the speed at which I start hearing the sound), I have observed no leaks, or funny/burning/hot smells, no smoke of any kind and so I guess I will keep on driving until I figure out what it is or until something changes that lets me pinpoint the issue.
HarryR
Get some painter's tape (will not harm paint) and tape the seams of the hood. Put baggies over the side mirror's. Tape on wipers, etc, until you find that the noise stops. Then start removing little by little until it appears again. You found it.
