Following the hack instructions for adding intermittent wipers on my 2003 986, I purchased and installed the potentiometer and relay. When I switch the wiper selector to intermittent and dial the potentiometer all the way to the right (longest delay) the max delay is about 2 seconds. Turning the potentiometer to the left one click or more (shorter delay) results in no delay. All other wiper functions operate correctly. Can anyone suggest what I might troubleshoot first?
-Tony
  • 7 years later...
Hi, I've just added the variable intermittent wiper hack. Is the max delay as Tony asked just 2 seconds? As there is very little difference between max and min, or is that normal?
Thanks, Andrew.
Hi Loren, Ah, is it this one 257-268carrera-windshield-wiper-relay? If that is the case how do I set the relay? As mine is the 911 one. Thanks, Andrew.
Nope, no adjustment on the relay, or at least the one I need. Local OPC tells me there is a problem with the dial, so i'm waiting on a new one. With no wiring and just using the relay I get about a 30sec gap. Connect in the dial and it drops to 2 seconds.
All sorted, it seems there are two different dials. The first one had only have 4 clicks, the second one has a lot more and works fine. :-)
