Does anyone know if the C4S windshield contains something that would prevent my turnpike E-Zpass box/sensor from working? Thanks in advance, Paul
I do not know about your C4S, but my X5 has the same problem. If I hang the sensor out the window it works great. The same is also true for my parking garage entry sensor.
I do believe that both Porsche and BMW use the same glass.
DFo yoou have the radio antenna enbedded in your front windscreen? if so try to mount the sensor to the side and below or above that vertical and horizontal wire that runs through the glass.
HarryR
That's funny. I have actually had the same problem with the Fastrak system in California. It works just fine on my other car, but doesn't work on my 996 no matter where I place it on the windshield. Hanging it out the window works fine. I thought it was just me.
