Does anyone know the offset measurement of a standard 996 C2 front and rear caliper? By offset measurement, I mean the center line to center line distance between the mounting bolt holes and the rotor.
Also what are the minimum and maximum rotor thickness that can be used with the above caliper?
Many thanks,
Mike
