Is it possible to get information on removal of stock seats and install of GT3 seats and in addition the removal of a Brey-Krause harness bar with the install of Porsche harness roll bar. Thanks
drbehavior
There is nothing unusual about the seat replacement.
1) disconnect the battery
2) unbolt the seat (requires torx socket) (you may have to pull off the plastic covers that cover the front of the seat rails). You can slide the seat forward and backwards to get access to the bolts.
3) tilt the entire seat backwards and undo electrical connection
4) take seat out (it is a good idea to cover the door sill with a blanket or something so you do not scratch it).
Install is the reverse.
To undo the BK bar just undo the bolts/nuts. If you need detailed instructions you can get them from www.bkauto.com.
Forgot. Before you install the GT3 seat you have to either transfer the seat belt receptacle from the stock seat or by another one.
