My fanbelt warning light comes on but the belt seems to have enough tension. Seems to me that the sensor is too touchy. Is the sensor designed to sense a very slightly loose belt, or is it bad?
Jeffo
  • 8 months later...
How do you know it has "enough" tension? What were the readings (increments) you got with the Porsche special tool 9574? Did you get these readings with a cold or warm engine?
the belt tension is critical on these engines, they need to be checked with the "cricket". you can check the sensor also, take it off and work it and watch light or with an ohm meter
