2011 958 Turbo Air Suspension will occasionally store error code "257 Pressure sensor, signal line short circuit to B+" when raising to higher level. Any idea what part may be causing that issue?
The air suspension still works and will quickly raise/lower to all levels despite the error. Also no signs of anything leaking. I recently replaced the rear air struts and air compressor and they seem to be working well except for this occasional code.
