Charcoal Canister on the Panamera in rear driver side wheel well?  I have a fuel smell in my car when the AC is on and recirculation is off (mainly when car is not moving).  I want to check the lines going to the canister and also the purge valve (if I can find it).  Not much info out on the Panamera relating to this topic.   I also read that the catalytic converter seals may be bad.  When bad, they can produce a fuel smell in cab.
:welcomeani:
It is always helpful to give us the model year and exact model of your car.
Yes, the canister is between the fuel tank and the luggage compartment -- accessed by removing the rear underbody protection cover.
If you have a charcoal canister leak then the car should give you a fault code as the system is tested every time you start the car.
It does give me an engine fault, drive on possible.  I don't have the reader, but it indicates a small EVAP leak and a large EVAP leak.  I am going to look at the purge valve as well.
