Charcoal Canister on the Panamera in rear driver side wheel well?  I have a fuel smell in my car when the AC is on and recirculation is off (mainly when car is not moving).  I want to check the lines going to the canister and also the purge valve (if I can find it).  Not much info out on the Panamera relating to this topic.   I also read that the catalytic converter seals may be bad.  When bad, they can produce a fuel smell in cab.
:welcomeani:
It is always helpful to give us the model year and exact model of your car.
Yes, the canister is between the fuel tank and the luggage compartment -- accessed by removing the rear underbody protection cover.
If you have a charcoal canister leak then the car should give you a fault code as the system is tested every time you start the car.
It does give me an engine fault, drive on possible.  I don't have the reader, but it indicates a small EVAP leak and a large EVAP leak.  I am going to look at the purge valve as well.
On 4/7/2025 at 4:34 PM, ZDParkeRx said:
I'll stick my icarsoft cr pro on it tonight and check
I just got my code reader back from my friend today.  I have:
EVAP System Leak Detected (Large leak) & (very small leak).
I have a 80730E - Exhaust Gas flap 1, faulty
On EVAP Monitor (0.040"): Test Value 0.450s, Minimum Limit 0.850s Max Limit 65.535s with Status Fail
I've purchased several OEM gas caps with no positive results.  I also fixed the Exhaust gas flap just now.  No idea what the EVAP Monitor 0.040" is about
