I own a 99 Boxster 2.5 which I left in a friend's garage during a 6 month deployment. Don't know if the car has been started and run periodically. If not and the battery is dead, what is the sequence of events to get the vehicle operational again? Will doors open with the key if battery is dead? Thanks.
W dead battery, you'll need to manually unlock the door. if your front hood release is electric, you'll need a spare battery w cable to connec to the fuse box by foot well inorder to release the hood. If it's manual release (which I think a 99 is), it'd be easier.
You can then charge the battery or replace it if charging doesn't work. If you aren't handy, you can get a cig lighter charger that will charge it over a day or so. Otherwise, a decent charger for $40-50 will do.
You should look into changing fluids, inflate tires as needed. Also, give the car a good detail.
Thanks djantlive-Do you think it's necessary to change all fluids? I changed the oil prior to storing, and the coolant is said to be good for the lifetime of the car (whatever that means). Anyone recommend a good detailing shop in San Diego area?
