Backstory, I had my 996 out on the frozen lakes racing. pretty common done it a half dozen times with this car, but it was particularly wet this last weekend.
Drove it home, 1.2 hours away, turned it off, and now wont start. turns over plenty fast no issues there.
read the codes, even though there was no CEL, and it was all 6 coils dead. found a post somewhere saying that the C2 fuse controls that, and lo and behold the C2 fuse was popped. installed a smart fuse, it pops when you turn the key to run.
that post also said, with the smart fuse in, start checking connections. so i pulled the fuel pump relay, still pops, pulled the MAF, still pops, pulled each 02 sensor, still pops. and pulled coils 1 and 4, still pops. didnt pull the other coils cause id have to take off the exhuast to get in there, and i dont think the short is there anyway. doesnt match the symtoms.
i figured id kicked up some snow/ice into the foot well and there is some water in the fuse box/relay box. but its been two days in a heated garage, with a box fan blowing and all the doors windows etc open, and still popping C2.
oh, i also got it fire up once, when i was rustling with fuses, and i had a jumper in the fuel pump relay, and it started and ran. but i have not been able to repeat that. now it pops whenever the key is turned. so something is/was moving though the system.
so like the engine is fine, everything works, there just is a short somewhere, and i have no idea where. still thinking its water intrustion. i had some weird problems with another ice racing car due to water getting into the iginiton switch, and they just went away when it dried out. so i think thats the problem here, but no idea how/where to look next. 2 days with a fan blowing on it seems like it should be enough. no visible water found anywhere on the car now after sitting in a heated garage for 2 days.
video for clicks:
checked the vario cam solidnoids, both ohmed to 12 ohms, so close enough on my cheap meter.
oh, its a 99 FYI.
pulled the fuse box off the back wall of the footwell, it seems dry, i dont see anything.
i litterally have no idea what to try next. it should work. it did work.
C2 (30A) is:
- IGNITION
- INJECTION
- OXYGEN SENSOR HEATER
Had any problems with your ignition switch?
Any custom wiring (i.e. aftermarket radio?
yup, i found the wiring diagrams. C2 is linked to a lot of stuff but the first place it goes is to the fuel injection rely. but pulling that relay, still pops the fuse. so its between the relay and the fuse, but there is nothing there. the other place C2 goes to is the oxygen sensor relay. i did pull all the oxygen sensors, and it still pops, but i have not pulled up the rear seat to look at the oxygen sensor relay.
power to C2 comes from the 80 amp main (F5), but if the 80 amp main had popped because of the ignition switch, there would be no power at C2, to pop C2. so its between C2, and the rest downstream, but not on the fuel injection relay side. and not the oxygen sensors themselves. so its in the wiring to the relays likely right?
no aftermarket wiring that i know of. no issues with ignition switch that i know of.
Edited by gerglmuff
yeah and its a common failure for sure. its also a place water can get into the system and you not notice, and weird things happen when water get into an ignition switch. i had a miata on the lake once, water in the ignition switch and it wouldnt turn off. key in the off position, key pulled out, it would happily run. had to kill it with the foot on the brake, pop the clutch, and then go in the back and disconnect the battery because otherwise it would drain, cause the ignition was still on. 2-3 days, the water in the switch dried out, never had a problem since.
i'll see if i can check that out tonight. its as least as likely a source of a weird electrical issue as some wire no one has touched in 25 years suddenly having a short it in. i dont see it in the prints, like how a short in the switch would lead to a popped fuse, but you never know.
ok, new data
i checked the ignition switch, blew it out with compressed air, didnt seem to have any effect, looked clean/dry etc.
then, following the wiring diagram, i found and pulled the oxygen sensor ignition relay (#2 in the rear seat relay box). and that shut it up. i tried to start it like this, but it didnt take.
i tried switching out the relay for one of the spoiler relays (they look identical), and C2 popped again.
so, i think that means the short is somewhere behind the relay, right? that means its a coil, or injector thats shorted? or the ECU?
more data ...
pulled out the ECU, cause i was in there. again looking for water etc. has a sticker on it from "specialized ECU repair" that says it was in for "testing only (set)" in 2021.
feels kinda like the ECU popped.
alright dug into this issue.
- not the ECU (tested by ECU repair company)
-not on the fuel pump relay side
-is on the oxygen sensor/injection relay side
-disconnected oxygen sensors, still pops
-disconnected the ignition coils, still pops
-cant really get to the fuel injectors, but they do not have continuity with ground from the X59/1 plug to ground.
does not pop when X59/1 plug is unplugged.
did find that the X59 plug was full of water, blew it out with a air compressor ... still pops C2.
blew out the oxygen sensor plugs ... still pops C2.
so the wiring doesnt have a short, all the things at the end of the wires are good, connector appears good.
i still think its water in the system somewhere, and the X59 was full of it, but that didnt fix it.
but im again at a total loss.
so, after 2 days in rice, the X59/1 and 2 are both bone dry. still pops the fuse.
so i used the new air compressor to blow out the ignition switch, still pops.
i have a spare ignition switch, so i went to swap that in, only to find out its not the right switch. **** pelican as usual.
but i did take the whole switch apart, confirmed it worked, blew it out, sprayed some dry lube in it, and put it back in, and it still pops.
so there is literally nothing else to do. everything is good.
the only thing left i fear is literally un-looming the entire harness and visually checking the whole thing.
does anyone have *ANY* possible ideas? i really dont want to have to drop the engine and pull the intakes to visually check the wiring. but i dont know what to do next, cause everything works. except it doesnt.
Edited by gerglmuff
someone said bad variocam solinoids can pop the C2 fuse ... so i unplugged them ... still pops.
so, im at, calling specialized ECU repair, and demanding the video of my ecu running a car (they claim to have it). casue at this point i dont believe them. unplugging the ECU does make C2 hold, just like X59/1.
and visually inspecting the entire harness (which requires engine dropping).
