To kick off the new year, I broke the front, upper screw mount arm on my 996's alternator (don't ask).  Normally I would just replace the alt but it's time to take it to the shop for some work anyways.  Question is, if I install the alt with only the bottom screw, will I be able to drive it 5 miles to the shop without the alt-torque destroying something or should I tow?
I would try running it in the driveway for a few min to see what happens; if nothing goes wrong, you should be able to drive the car a few miles gently to the shop.
